I just switched from Inventor 2018 to 2021. My school does not have a plotter printer, so I have had my students create all their multiview drawings in A size Landscape so we can fit the three views and the isometric. Now in 2021, the only A size sheet format I have is 'A Size_ASM_1 view_wPL', which is a portrait orientation. Where did all my other sheet formats go and how can I get them back? Thanks.
Solved by mcgyvr. Go to Solution.
Seems they "streamlined" that in 2021..
Easy to just create your own or edit the sheet to change orientation..
Oof. 'Streamlined' indeed. Thank you.
So if anybody else wants a quick fix for a sheet other than the three in the drawing resources folder, right click your shett and select 'Edit Sheet', which should give you a window with various options. From there you can create your desired sheet. So yeah, streamlining means at least one extra step if you want anything other than the three basic options.
