Inventor Forum
Help on "Detail" view editing
5 REPLIES 5
Logan_Cairney
208 Views, 5 Replies
Hello all,
Is there anyway i can remove this box around a detail view once pulled out?
the box needs to be removed to add relevant information such as dimensioning etc. but u cant seem to figure out how to remove or hide it? (I'm happy to keep the "A (1:1)" if possible but not the end of the world if that needs to be hidden in order to hide the box)
Any help appreciated, thanks in advance
Tags (3)
Labels (2)
5 REPLIES 5
mikejones
in reply to: Logan_Cairney
Is it the dotted line box or the solid line that you're referring to?
Autodesk Certified Professional
Logan_Cairney
in reply to: mikejones
Apologies for not making this clear, i mean the solid line
Logan_Cairney
mikejones
So are you wanting it to look like A below rather than B?
If so then you can change the view properties by RMB clicking the view in the browser and change the Cutout Shape
James_Willo
Hi, you can try this.
Create a new layer in the styles editor with the lightbulb off.
Find 'detail cut line' in object defaults and select this layer.
It should now hide the outline. This will apply to all details in the document.
James W
Inventor UX Designer
Technology Administrators
