I am trying to create a helix that is tangent to the straight lines shown above? Can anyone help with a workflow for this?
thanks in advance
thanks in advance
Solved by jeremy_wasserstrass. Go to Solution.
Solved by Frank-Oosterwaal. Go to Solution.
This one is interesting! There might be a simpler way to achieve this but this is what I could think of. Look at the screencast. I also attached my part (2017 file). It has different dimensions but it's the same principle.
Hope it helps, good luck!
cheers frank
haven't had time to try it as I'm now on an acad job 😞 but had a quick look at the screencast and it looks like what I am after...
thx!!
cheers frank
thx!!
Whoops, looked at my model again and made a mistake (see picture).
Ignore the splits of the helix and create a new helix after splitting the tangent arc, new part attached.
Good luck!
Edit: Now with part
Good luck!
Edit: Now with part
Attached is an alternate way of accomplishing this.
thanks Jeremy, 🙂
