Header in Revision table not aligned
Ove_Sjögren_NTI
Ove_Sjögren_NTI
Text in header is not aligned in revision table header when using lowercase.
In a textbox there are a button "baseline justification". Would be nice if a similar function exist in the revision table.
CGBenner
@Ove_Sjögren_NTI
Hi, I believe it is the lowercase "p" that is setting this off... any lowercase letter that extends below the "line" of text has a tendency to throw off the centering.  I've seen this in other programs as well.  As of today I think your only workaround is to stick with all caps on your tables.
Have you added this suggestion to the Ideas forum?  I see that you have posted one idea already.... is it this one?
Chris Benner
Ove_Sjögren_NTI
Thanks Chris,
You're right, it the lowercases that extends below the lite of text causes the issue.
I have posted this as an new idea (wasn't this one).
Header in Revision table not aligned - Autodesk Community
BR Ove
