Which processor and memory configuration would you say is best for Inventor 2016, Xeon with ECC RAM or i7 with non-ECC RAM?
We dont do any analyzation of parts or anything like that we just create puzzle pieces and fit them together (gross simplization)
I know this will potentially start a flame war and get ridiculed for being answered hundered of times already but since its Inventor Answer Day I thougth I would give it a shot.
Mitchell
Solved by -niels-. Go to Solution.
Solved by VinodBalasubramanian. Go to Solution.
This is a valid question. Based on the outline spec you provided, both looks good hardware. I would recommend you to use the system requirements below as a guideline for RAM and graphics which are the two crucial hardware requirements for optimal performance.
You could also check the below article for more info around this,
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-46E714D8-8D90-4D1D-BD6D-8B30ABF78E50
System requirements
Hope it helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
