Getting open ipt/iam into current assembly
snappyjazz
snappyjazz
We work on large assembly files. Trying to add components can take a couple of minutes. I used to use SolidWorks which the insert command the option to add an "open" component, or browse. In inventor I've found the most convenient way to add an open component is to copy and paste. I think this is slow because it uses the clipboard. Another option is to "place" it which is faster, but that's a bunch of clicks through our folder hierarchy. I also know of using the "Insert to CAD" from vault. Are there any other methods to get a subcomponent into an assembly?
CGBenner
@snappyjazz
Hi, if you have a component open, I believe you should still be able to add it to an assembly as long as it is saved.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
johnsonshiue
Hi! Or split the document windows and drag and drop. Save is not required.
Many thanks!
Software Test Engineer
snappyjazz
@johnsonshiue @CGBenner
Thank you!
