It only works on base solids. If you have surfaces, then it will not
function. When opening a STEP, IGES file or another format that is a surface
model or that contains surfaces it will not work untion the surfaces are
stitched into a single solid. When opening non-inventor files always select
and check OPTIONS before opening the part (attached)
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP2, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
