Inventor Forum
Gear teeth features
11 REPLIES 11
Message 1 of 12
626 Views, 11 Replies
Gear teeth features
I was hoping someone could help me model these interesting features on gear teeth. I've been trying for a long time and I have no idea.
Polišenský
20210716_131022.jpg20210716_131048.jpg20210716_131058.jpg20210716_131105.jpg20210716_131128.jpg20210716_131135.jpg
Gear teeth features
Polišenský
11 REPLIES 11
Message 2 of 12
Casey.P
Casey.P
Are you willing to share your file so that we can help solve your issue?
Thank you!
Thank you!
Message 3 of 12
JDMather
JDMather
From the tool marks you can see how it was done in the real world.
I would do it essentially the same in Inventor.
Attach your *.ipt file here if you can’t figure it out.
(Did you Export you cosmetic tooth profile to true involute teeth?)
Message 4 of 12
I think I figured it out. Anyway, I'm attaching a file so you can see how I did it. Perhaps there is a better way.
Message 5 of 12
in reply to: JDMather
I definitely didn't change the tooth profile. I kept it as it was.
Message 6 of 12
JDMather
JDMather
What is your purpose for this model?
If all you want is something that sort of looks OK (cosmetic) then the simplified tooth profiles might be OK, but if you want to model a real gear...
Message 7 of 12
I would like to have it as real as possible. Unfortunately I don't know how to do it. Is there some sort of tutorial online?
Message 8 of 12
johnsonshiue
johnsonshiue
Hi! The precise geometry in this case has to be created using Solid Sweep. Try defining the cutting tool and identifying the path. Next, use Solid Sweep to create the "cut" volume. Then, mirror and pattern it. Lastly, use Combine feature to cut the body.
Many thanks!
Software Test Engineer
Many thanks!
Message 9 of 12
JDMather
JDMather
3:10-
3:10-
Message 10 of 12
IgorMir
IgorMir
Here it is. IV2020 file. The model is far from being the optimal but it might give you a starting point.
I will put some more thoughts into it later on.
Cheers,
Igor.
Web: www.meqc.com.au
Cheers,
Igor.
Message 11 of 12
WHolzwarth
in reply to: IgorMir
WHolzwarth
Many years ago I've been working in this industry. The procedure is called gear tooth chamfering, with special shaped milling tools.
It can be done with fixed workpiece, milling one tooth, and then rotating the workpiece to the next tooth. Two tools are working on different positions, one for each side of the roof.
Another method is done with continuous rotation of the workpiece, and synchronized motion of the tool. See an old-time video, for only one tool shown.
Walter Holzwarth
Walter Holzwarth
Message 12 of 12
IgorMir
IgorMir
Thanks, Walter.
I hope - the OP will appreciate our efforts. 😊
Here is one more attempt to create the cut (IV2020). It is a bit cleaner to what I have posted yesterday. But still - the depth of cut (controlled by d77 parameter) is a manual work. I am missing something obvious in creating the cutting geometry, but can't pin point it yet.
Cheers,
Igor.
Thanks, Walter.
Cheers,
Igor.
