So I made a digital counter that has four digits. The digits are sequentially geared together at a 1:10 ratio using a motion-rotation mate such that once the first digit has fully rotated, the second digit increments by 1 and so forth. I then geared the first digit 1:1 with the handle. Finally I geared the first digit to the carriage with a 1:(1/6) motion-rotation-translation mate (due to it being a 6 TPI leadscrew). When I turn the handle slowly, the digital counter increments appropriately and the carriage raises correctly. However, if I lift the carriage with any amount of increased speed, the digital counter skips. To me this makes no sense as everything is geared together and there should be a mathematical function that links the elevation of the carriage to a specific digital count. Why does the counter skip and the mates lose track of their relationships?
I can think of another way of doing this using parameterized mates and an excel sheet.... but I was trying to avoid doing that.
Any help or suggestions are greatly appreciated.
Thanks!
Attach assembly here.
Attached is the DigitalCounter assembly pack and go. Please let me know if you have any difficulty opening it. Thanks!
Screencast: https://autode.sk/3nPO0nu
What i did is:
- gear all digits with the first one. The second with the first (0.1), the third with the first (0.01), the fourth with the first (0.001).
- Replace the rotational constraint between Ratchet Arm & ACME threaded rod with a fixed constraint (there is no relative movement between these two parts).
- Use Drive Constriant to move parts in a controllable way instead of doing it mannually.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Thank you for working on finding a solution and for the screencast. I will attempt your technique later this afternoon when I get a minute. I appreciate the help and will let you know how it turns out.
