Friday pictures 4-30-'21
-niels-
Mentor Mentor
-niels-
It's a dreary, gray Friday where i am, so let's post some pictures to brighten the day a bit.
I designed a little (tiny, perhaps) tubeclamp that i 3D printed... but i guess i did stuff wrong on all departments.
I forgot to model in tolerances, didn't realize how tiny it was and made screw threads that are way too fine, added some expansion settings in my slicer to clear some wall thickness settings not realizing the consequences of doing that, placed the 2 halves too close together so i had massive stringing between them...
Yeah, i could've done better... but still amazed at the print result with those tiny tiny threads.
(they didn't fit because of the expansion, but i believe they would've worked otherwise.)
The filament had some issues as well, think i need to dry it, but that's for the next attempt.
Anyway, here is a raytrace and a photo of what i tried to make, to give an idea of size: the inner diameter was 9,5mm.
(like the fact that the selected solid shows up in the saved image.)
What's keeping you all busy?
Share if you can!
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
JDMather
I’m a beginner just need help with modeling - Autodesk Community - Inventor
Fouad-l
Hello everybody!
This is a 80 mm Reflector mirror for photoelectric photocell i have modeled for one of case erecting machines i have designed.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
cadman777
Looks like some of my failed prints using ABS.
The way I do threads is make a thick solid shell and use a tap or die or chuck it up in a mini lathe and cut them w/a bit.
Works like a charm every time.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
-niels-
The way I do threads is ... use a tap or die or chuck it up in a mini lathe...
I have none of those tools at home, so sadly not an option.
I've printed a few threaded objects and so far the threads always worked, so i know it's possible... i just didn't think this one through. Still haven't given it a 2nd try...
Niels van der Veer
The Netherlands
