Inventor Forum
Frame Reference Skeleton does not update correctly
14 REPLIES 14
Message 1 of 15
mallorn
3947 Views, 14 Replies
I have a problem described in the title.
Generally the rail should look like the state it loads.
Please try to change H1 parameter (raise of slope) in main skeleton file... from 100mm  to 300mm... the reference skeleton will not follow the changes in "3D Sketch1".
Please help...
Tomasz Malinowski
14 REPLIES 14
Message 2 of 15
johnsonshiue
in reply to: mallorn
Hi Tomasz,
Many thanks for sharing the files! I took a quick look at them. It does look like a bug to me. Somehow the Frame sub lost associativity with some of the curves in the skeletal part. This does not make sense to me. I will work with the project team to understand the behavior better. In the meantime, you may need to delete the members and insert it again to re-establish the link.
Thanks again!
Software Test Engineer
Message 3 of 15
Sergio.D.Suárez
I can not see the file because I have IV 2018, something similar happened to me, the skeleton0001 was not updated when modifying my skeleton, the error was because I had linked my skeleton parameter to my main assembly, once the folder was deleted Parameters linked from my skeleton in my assembly correctly updated my skeleton0001 when modifying my skeleton. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 15
mallorn
in reply to: Sergio.D.Suárez
Thanks, yuvilo_, but this is not the case.
I removed all the links before the file was sent here.
Tomasz Malinowski
Message 5 of 15
jan_priban
Hello Tomasz,
thank you for reporting this issue. I can reproduce mentioned behavior from scratch as well. Let me inform our developers.
Regards
Jan Priban (Inventor Frame Generator department)
Message 6 of 15
Message 7 of 15
Hi! Please share the files (iam and ipt files) here or send them to me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Message 8 of 15
andrewdroth
in reply to: johnsonshiue
I think I'm having the same issue here.
Updated my master part and none of my frame generator parts are moving. The reference skeleton does not math the lines it was defined from.
Updating and Rebuild All does nothing.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
Message 9 of 15
andrewdroth
in reply to: andrewdroth
I think I fixed it?
I just installed the latest update, restarted the computer, loaded the assembly -> Rebuild All and BOOM! It all snapped in place.
Nice
I nearly had a heart attack.
Andrew Roth
rothmech.com
Message 10 of 15
johnsonshiue
Hi Andrew,
Are you on 2020.2?
Many thanks!
Message 11 of 15
garethW67J9
Hi Johnson,
I'm working in Inventor 2022. And am looking for a solution to the above issue. It appears my frame reference skeleton does not update with the master skeleton. I've just applied the latest Feb 18 2022 update with no joy.
There is also a strange thing happening, when I place new members onto the visible skeleton. The parts are placed and appear significantly offset. As if the reference frame is 300m away.
Message 12 of 15
johnsonshiue
in reply to: garethW67J9
Hi! I vaguely remember there was a regression in 2022 RTM build. It should have been fixed on 2022.2.2. Please make sure you install 2022.2 update followed by 2022.2.2 update.
If it still does not work, please share the files here or with me directly johnson.shiue@autodesk.com.
I can take a look to understand the issue better.
Many thanks!
Message 13 of 15
NELSON_F_ORTIZ
Hola a todos, sucede el mismo problema en la version de inventor 2024.1
Message 14 of 15
jan_priban
in reply to: NELSON_F_ORTIZ
looking into our tracking system I see comment: "Validated using R 2022 update for newly created assembly. Not working for old datasets".
So Autodesk fixed Frame Generator update of curved frames triggered by skeleton change, but unfortunately for new assemblies only. Just revalidated using R 2024.1.1 (I repopulated 3D skeleton). See image taken using R 2024.1.1. please.
Regards
Jan Priban
Message 15 of 15
NELSON_F_ORTIZ
in reply to: jan_priban
He actualizado a la ultima version de inventor, aunque esto no solucionó inmediante el problema, como opción alternativa para forzar dicha actualización se me ocurrió actualizar otra parte del layout, esto hizo que el skeleton se actualizara y tomara también los cambios que requería antes, finalizado esto, restauré las medidas a como lo necesitaba y listo.
