Here is my interpretation of the part based on the single .jpg print.
This version is not bent double, because the print does not show that information.
I used two user parameters for the Rod Diameter and the Rod Bend Radius to build the part. That way I could use those parameters in different dimension equations or in different sketches to control the part geometry. I guessed that the rod was 0.25 diameter with a 0.5 centerline bend radius.
I planned my model so that the origin work planes would be useful when I assemble the rod to the rest of the components in the design. I used construction lines and dimension equations so that the sweep path has the same dimension scheme as the .jpg drawing. If I am modeling an object from an existing print, I tend to build the sketches and features with the same dimensions. I think modeling that way helps me capture the original designer's intent. I also think that it is easier for me to compare my model to the 2d print.
I created the "Rod Profile Sketch Plane" using the Normal to Curve at a Point workplane command. https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-38A9748E-FA2D-44D3-928C-DFE1326A9385
Steve Walton
Inventor 2025
Vault Professional 2025
