I need help with creating a negative mold of a file
maanasa_jayachandran
Observer Observer
Message 1 of 8
Observer
Observer
Hello
I am trying to create a negative mold part of this mouse skull (just the top surface). I would appreciate any help! I have attached the files. mus is the mouse skull that is part i need to mold and I create a extruded block to mold the mouse skull.
Thank you
Replies (7)
Message 2 of 8
Wayne.peacockSF88J
You will need to put both items into an assembly, and then within the assembly, you need to open the mold and use the copy object tool & sculpt tools.
Its best to watch (and study!) this excellent video by Neil Cross on his Tech3D youtube channel.
https://www.youtube.com/watch?v=LP4ArppuXno
Message 3 of 8
JDMather
@maanasa_jayachandran wrote:
...mouse skull (just the top surface).
How do you define "just the top surface"?
What is your intended Units for this skull?
Message 4 of 8
Observer
Observer
By top surface I mean this part.
Also intended units should be mm.
Message 5 of 8
JDMather
How much of the top - what is the height of the rectangle you sketched?
Can you Attach the original *.stl file here?
Message 6 of 8
Observer
Observer
Here is the assembly.
Message 7 of 8
JDMather
No parts?
The ipt that you attached before is incorrect units.
Requested file was *.stl .
The requested information was height of red rectangle.
Forget Message 2 by @Wayne.peacockSF88J  - that was a distraction from the real issue. Note that no solution was provided.
Message 8 of 8
Observer
Observer
Here is the .stl files. I was able to convert the mesh into a part. The dimensions are on the top YZ plane (14 mm by 10.5mm) and the dimensions from the side XY plane (14 mm by 3 mm). Basically I am trying to create a cast of the top of the skull.
