Inventor Forum
Frame member cut extrude bug - Inventor 2018
3 REPLIES 3
563 Views, 3 Replies
Hello everyone,
I am trying to cut extrude a frame members to a specific shape using EXTRUDE CUT, as Inventor is unable to cut "complex" shape using TRIM/EXTEND command.
I did the EXTRUDE CUT in the frame assembly, or if I have many frame members it would be too long to repeat it for each members. I get the right shape in the frame assembly, but when I open the frame member part, the frame member has no cut.
A-0009.iam is my main assembly --> image 1
TF-0002.ipt is my "template" --> image 2
A-0009-FR.iam is my frame "assembly" --> image 3
Hello everyone,
Labels (5)
3 REPLIES 3
JDMather
JDMather
Not a bug - this is the same as in the real world.
If you assemble two parts in the real world and then cut - the cut does not magically appear in parts before assemble.
But in Inventor you CAN edit the parts in the context of the assembly and therefore the changes do appear at the part level.
Attach your assembly here if you can’t figure it out.
gcoombridge
gcoombridge
Also upgrade to 2021 if possible.. Trim/extend has been improved to allow curved cut faces..
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
in reply to: JDMather
So if there are 50 frame members to cut with same profile, I would have to cut it one by one at part level? There is no simple alternative?
