Could any one provide solution for this how do i delete the Second DIN From the frame
Generator...?
Did you create a library of your own and published parts that you can use in Frame Generator?
Hi! Is it possible the custom content is also based on DIN? I thought you could use Filter option in Content Center to disable DIN standard content.
Many thanks!
