Inventor Forum
Frame generator - won' t close
2 REPLIES 2
andrew.millerJ3SXR
474 Views, 2 Replies
I am using frame generator to make a frame.  I have inserted my frame members along the lines I drew on the part file, which I inserted into the assembly.  The frame parts show up in the preview just like I want them to, all green.  The window pops up "Create New Frame" with the default locations.  I click "OK" and and the window disappears and everything freezes.  If I hit my escape button, my frame disappears and Inventor unlocks, but I have no frame.  If I wait, I get a prompt "Select a line or draw a window" but I can't select anything.
I've rebooted my computer, I made an ultrasimple drawing and frame, and I've used frame generator many times before in the past without this issue.   I appreciate any suggestions!
2 REPLIES 2
Are you working with multiple monitors? My assumption is that there is another dialog box that needs your input before continuing to close the frame generator window. Give this a shot when you get to that point again: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog...
Its from a 3ds forum but it applies to inventor too.
Construction Engineer, PE
Thanks - that was the problem!
