Frame Generator with Custom Structural Shape
 So I sketch my frame layout and bring it into a new assembly.
Then I go to "Insert Frame" and the list provided does not give me a profile that I need.
What do I need you may ask? A mild steel square tube .75" X .75" with a 1/16" wall.
Tutorial shows I can create my own structural profiles and use those. So I create one.
But, now how do I get my custom Structural Shape to show up in the dropdown list in the Frame Generator?
Or did I miss something?
Allan
Inventor 2016
Newbie
P.S. Tried sweeping....didn't like that at all.
SBix26
Creating custom profiles really does work, but you have to follow the procedure meticulously, and be absolutely certain that they are published to the Structural Shapes section of your Read/Write library.
But in this case, why not just copy the square tubing family from the ANSI libary to your R/W library and then add a new row to the table?
Sam B
Inventor Professional 2016 Update 2
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Thanks for your input Sam. And as my sign-off states "newbie" so thanks again.
You spoke of read/write library and just adding a row to the table.
Would you care to enlighten me as to how to bring that ANSI table local?
Allan
SBix26
Don't have time to explain in detail, but open the Content Center Editor and poke around.  You should be able to create a new library, and then copy a family from the ANSI library to your new one.  If I recall correctly, you have a choice of keeping the new family linked to the source, or not.
As you have probably discovered, the installed libraries are permanently read-only, so you have to create your own in order to customize anything.
Good luck!
Sam B
Vault Basic 2016
Mark.Lancaster
These two links will walk you through the steps....
https://www.synergis.com/2014/02/28/working-with-inventor-content-center-part-1-of-3/
https://www.synergis.com/2014/03/17/working-with-autodesk-inventor-content-center-part-2-of-3/
https://www.synergis.com/2014/03/28/working-with-autodesk-inventor-content-center-part-3-of-3/
Mark Lancaster
