Frame Generator parts have incorrect diameter
- Mute
- Permalink
- Report
I am currently working on an assembly using frame generator with about 200 pipes made with frame generator and the OD of the pipes is showing the incorrect size.
In my specific case, I am using 2 1/2" Schedule 160 pipe. The actual chart value of the OD of such pipe is 2.875" (2 7/8"), but frame generator models it using 2.88".... Clearly a case of rounding to 2 decimals. In most cases this would be negligible, but in my case I have a model that needs to have these pipes extremely close. Practically touching in my model, and actually touching in real world application due to tolerances. In my case I need a center to center distance of 2.879, which would normally leave a very small clearance, but being that FG models it at 2.88, it actually creates a .001" interference. This causes my drawing views to need "interference edges" visable, but I cannot dimension those.
Is there a way to change all of my frame generated pipes to have an exact 2.875" Outside diameter so that I can properly dimension them?
Not sure why Autodesk would allow rounding to only 2 decimals in their created parts as it has a possibility to create such errors and does also affect mass and other properties. Probably just overlooked.
Any help is appreciated.
