Hi All,
You probably think that his topic has been done to death BUT!! I am having problems getting angles to show in the partslist. The only thing that shows up under the Custom properties CUTDETAIL1 and CUTDETAIL2 is the word CUT if there is any treatment, otherwise it is blank. I am using Inventor 2017. I have attached an example screenshot of the list. Any suggestions??
Thanks for your help.
Regards
Richard
Solved by johnsonshiue. Go to Solution.
Hi! I think these members have Trim/Extend end treatments as opposed to Miter. As a result, there isn't any angular value attached to the detail.
Many thanks!
Thanks Johnson,
The original frame was done by someone else so I wasn't sure how the ends were done, but this makes sense.
Regards
Richard
