Inventor Forum
Frame Copy
8 REPLIES 8
Message 1 of 9
ghmail16
955 Views, 8 Replies
Frame Copy
ghmail16
I have made a Door with Frame Generator and I want to make an other one like this with higher height. So I copied and
pasted the files of Frame with windows explorer and then changed the Frame Height of the new file assembly. But that changed the height of the first door also. I guess because the new door is still related with the old frame. What can I do to copy frame objects that I want to change partially
Frame Copy
8 REPLIES 8
Message 2 of 9
richiesuk
in reply to: ghmail16
richiesuk
use copy design
use copy design
Message 3 of 9
Curtis_Waguespack
Hi ghmail16,
Depending on the version of Inventor are you using, you might be able to use the iLogic Design Copy tool. It was included in the 2012 and 2013 versions. It will copy and update the internal links of the frame. Note that you don't need to have used iLogic to use the iLogic Design Copy tool.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3747-iLogic3...
The Copy Design tool in the SDK will work as well.
Paul covers both of these tool here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
I hope this helps.
Curtis
Hi ghmail16,
I hope this helps.
Curtis
Message 4 of 9
ghmail16
I used
Tools>iLogic>iLogic design copy
but with Inventor open and all files closed.
Thanks for the help.
I used
Message 5 of 9
JorisSteurs1246
Hi Curtis
When I would do this workflow, i get a message that the skeleton could not be copied and that the origingal skeleton wil be used. This is not good because your original frame will be messed up when making changes at the new frame.
Is there a work around for this?
Joris
Hi Curtis
Joris
Message 6 of 9
cbenner
in reply to: JorisSteurs1246
Message 7 of 9
JorisSteurs1246
in reply to: cbenner
JorisSteurs1246
Yep, Stand alone user, tried Vault many years ago but it slowed me down,
didn't allow me to go picking parts in old folders and some
other annoyances, so I didn't use it anymore since.
Joris Steurs
Design & Fabrication
www.distep.ee
Joris Steurs
www.distep.ee
Message 8 of 9
cbenner
cbenner
I agree Vault has it's share af annoyances, but I'd be lost without it.
Have you tried Design Assistant?  I've never used it with FG, so I don't know how it handles the skeletons.
Message 9 of 9
JorisSteurs1246
JorisSteurs1246
Yes DA gives the same complaint as the ilogic copy design tool.
Joris Steurs
www.distep.ee
Joris Steurs
www.distep.ee
