I have made a Door with Frame Generator and I want to make an other one like this with higher height. So I copied and
pasted the files of Frame with windows explorer and then changed the Frame Height of the new file assembly. But that changed the height of the first door also. I guess because the new door is still related with the old frame. What can I do to copy frame objects that I want to change partially
Solved by Curtis_Waguespack. Go to Solution.
Hi ghmail16,
Depending on the version of Inventor are you using, you might be able to use the iLogic Design Copy tool. It was included in the 2012 and 2013 versions. It will copy and update the internal links of the frame. Note that you don't need to have used iLogic to use the iLogic Design Copy tool.
The Copy Design tool in the SDK will work as well.
Paul covers both of these tool here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
I hope this helps.
Curtis
Hi ghmail16,
I hope this helps.
Curtis
I used
Tools>iLogic>iLogic design copy
but with Inventor open and all files closed.
Thanks for the help.
I used
Hi Curtis
When I would do this workflow, i get a message that the skeleton could not be copied and that the origingal skeleton wil be used. This is not good because your original frame will be messed up when making changes at the new frame.
Is there a work around for this?
Joris
Hi Curtis
Joris
For frames and tube & pipe assemblies, I've always had good luck with Vault copy design. But... you have to be using Vault.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Chris Benner
I agree Vault has it's share af annoyances, but I'd be lost without it.
Have you tried Design Assistant? I've never used it with FG, so I don't know how it handles the skeletons.
Chris Benner
Chris Benner
