Forcing a Quadrant Selection for a Dimension
ethan_howardMMXXV
Message 1 of 8
ethan_howardMMXXV
Typically, a green grip (shown below) will appear when dimensioning to the midpoint of a quadrant. I am dimensioning the overall for this sub-assembly. For some reason, this particular selection does not work. Inventor wants to dimension as a diameter dimension only (shown below). Is there a way to force the selection? In AutoCAD, I could use OSnap for quadrants.
Thank you,
-Ethan
Replies (7)
Message 2 of 8
SBix26
The green dot you show in your first image is not a quadrant snap, it is a mid-point snap.  An arc has a midpoint, of course, and a circle does not have a midpoint.
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
Message 3 of 8
ethan_howardMMXXV
@SBix26 In the second image, how do I select that circle for the overall dimension of my sub-assembly?
Message 4 of 8
-niels-
Workaround:
Start a sketch on that view, project the circle and draw a tangent line from it.
Exit the sketch and dimension to that drawn line.
I don't know if it is possible to do it without the workaround...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 8
ethan_howardMMXXV
That worked. Thank you. Can that be placed in the Inventor "enhancements" bucket? Meaning being able to dimension to any feature? Like AutoCAD, where you can use an OSnap to grab a quadrant, for example.
Message 6 of 8
-niels-
You can add your own request for improvement on the "Inventor ideas" forum.
If you post a link to your idea in this topic, i'll add my vote.
Niels van der Veer
The Netherlands
Message 7 of 8
ethan_howardMMXXV
Done. Thank you!
Message 8 of 8
-niels-
Added my vote.
For others that would like to do the same, the idea can be found here:
https://forums.autodesk.com/t5/inventor-ideas/drawing-osnap-selections-like-autocad/idi-p/10993840
Niels van der Veer
The Netherlands
