Inventor Forum
Force derived sketches to be construction linetype
2 REPLIES 2
julesgf
271 Views, 2 Replies
Hi All
Wondering if there is a trick to force derived sketches to be construction linetype?
I'm deriving complex sketches from the skeletal model file into part files and adding additional content to the derived sketches before using the sketch to produce features (extrude etc).
If all the derived content is construction linetype I can easily create the features, if not the loop selection is slow and clumsy.
When I update the derived content it returns to "normal" linetype.
I cant have the original sketch as construction as I need it to be normal.
I can create a new sketch in the new part and project all lines from the derived sketch but its a clumsy and slow process.
Any thoughts?
Cheers
JF
2 REPLIES 2
blair
in reply to: julesgf
Not with Derive, possibly you might be able to use iLogic to convert all "normal" lines in a sketch to construction lines.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
julesgf
in reply to: blair
Thanks Blair
iLogic crossed my mind but the job would have to be bigger to justify it as I'm pretty slow at crafting iLogic
Cheers
JF
Technology Administrators
