flat pattern
flat pattern
lkirit2000
Advisor Advisor
Message 1 of 15
flat pattern
lkirit2000
Hi
Please see the attached image, I need to make a flat pattern.
But it didn't capture whole face.
Then I made a half view ( cut by a plate at the center of thickness ).
How to do that?
Regards
Replies (14)
Message 2 of 15
cadman777
Please post the image...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 3 of 15
lkirit2000
Hi
Chris, please see the attached.
Message 4 of 15
JDMather
Did you Attach the correct file?
This is not a sheet metal part?
Message 5 of 15
lkirit2000
Hi
I created it in part environment.  This is not a flat sheet.
Message 6 of 15
robertast
This is what you want to straighten if your detail is already straight ...
Message 7 of 15
JDMather
Hand sketch or photograph of real world part(s).
Message 8 of 15
mcgyvr
@lkirit2000 wrote:
Hi
@lkirit2000  Please look at the file you attached.. It is NOT a part that could be flattened.. Its some rectangular extrusion with a small cylinder extrusion out one side. It looks like you may have posted the wrong file.
If not you will need to be MUCH clearer about what you expect to happen with that file.
Message 9 of 15
JDMather
Using default name Part1 is a very dangerous practice as you will eventually accidently overwrite some very important file.  (And of course, makes identification impossible unless you have one and only one Part1.)
Message 10 of 15
lkirit2000
Hi
I need to create a dxf file for laser cut the part. I couldn't create in one step.
Rgds
Message 11 of 15
robertast
@lkirit2000
Improve my knowledge, wondering how a laser can cut such a round part?
Message 12 of 15
JDMather
I didn't see this problem description in your original post?
First thing I notice is that, once again, you sketches are not fully defined.
Do you have any interest (after 3 yrs of using Inventor) to learn how to fully define sketches?
Message 13 of 15
cadman777
Here's some very good tutorials for Inventor:
https://www.trainingtutorial.com
Cheers ...
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 15
lkirit2000
Hi JDMather,
When I try with Save copy As, I couldn't get the Autocad Dxf Option.
I can see Autocad DWG file. How to bring AutoCAD DXF option ?
Rgds
Message 15 of 15
JDMather
We will have to start from the beginning - are you ready to do that?
