- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I wanted to make a flat pattern of a shell (attachments: WC.ipt and Pic 1.png). The problem lays in area of intersecting bends. (attachment: Pic 2.png). Flat pattern doesn't work (errors during update). Thickness is set to 50 mm so it is not a thickness case.
So then I did a second try:
Sheet metal > sketch > surface > flange one and second edge, it shows me a good surface with curved line, but this surface isn't created after all. (attachment below, second post: Pic 3)
All I want to get is the template with K factor = 1 which I can use to actually mirror that curved cut on a actual steel plate. I have got a template but it won't work for me (attachment below, second post: Pic 4).
I will be very thankful for any help
