Inventor Forum
flat pattern from sweep
2 REPLIES 2
627 Views, 2 Replies
I can not get this part to flatten.  Any help would be appreciated.
Levi
Inventor 2016
2 REPLIES 2
CCarreiras
Hi!
Go to "Sheet Metal default" and set thickness to 0.25in, as you have in the thickness tool
Tip: in thickness tool, it's better to have "Thickness" variable instread of a numerical value, this way, if you want to change global thickness, you only have to change it in the Sheet metal defaults, then the thickness tool value will update accordingly.
CCarreiras
in reply to: CCarreiras
Had to be something simple.
Thank you!!!!!
