Inventor Forum
Flat pattern always flipped
5 REPLIES 5
1007 Views, 5 Replies
This is actually in Inventor pro not fusion 360 but im thinking the solution may be the same. Whenever I create a flat pattern so i can export the file to sheetcam it flips and give me a reverse image. So everything I cut has the dross a cleanup on the wrong side, id prefer cleanup to be on the back even if it is minor.
Any ideas on how to change this setting?
5 REPLIES 5
CadManagerMoffatNZ
Hi Carter
you need to use the "A-Side" definition.
In your part (before you create a flat pattern) start the A-Side Command and pick the "Up / Good (If you using coated stainless steel). The flat pattern will now develop with this face up.
Hope this helps.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
JDMather
Other than setting the A-side, you can right click on the Flat Pattern node>Edit Definition and Flip.
johnsonshiue
Hi! Inventor and Fusion do share some similarity in Sheet Metal but there are differences. Please share the file here so forum experts can take a look and understand the behavior better.
Many thanks!
Software Test Engineer
hyperCut
in reply to: JDMather
Also have this problem in Fusion 360 but looks like fusion 360 does not have this option to change it ?
If you place the flat pattern on a drawing does the "front" come out correctly or flipped? If it comes out flipped in this case then the others recommending A-Side are correct, however if it is correct when you do this there may be a setting in the export configuration. I had an issue at one point where every time I did an "export face" the part would be upside down. In my situation all I had to do was edit an export configuration to not flip on export. While I haven't used sheetcam, Inventor Nesting can also flip on import depending on the configuration used, so you may want to look at import settings if they are there.
