Flat assembly destroyed, constrains flipped - FIX IT challenge
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Welcome.
I had dug up one of the old unsolved cases, and inspired by latest discussion decided to post it as a challenge for all who are willing to try their constraining techniques with this task.
It is flat assembly, that uses no flexibility and no range constrains. But there are no restrictions on how it should be constrained. All inventor valid technical solutions are accepted.
Assembly is now destroyed by the constrain solver. It was originally brought to this state by constrain solver, as user would not be able to do that. I had not been able to fix it in any other way than removing most of the components and building from scratch. But even than it was not stable.
Design intent is simple - This is to be constrained in the way so it's DOFs are equivalent to real life construction. (This was actually build and used on construction site).
Criteria for the challenge:
- it must be stable,
- it must be draggable within its proper envelope. So it was clear that constrains positioning upper beams can be applied separately from structure's internal constrain set,
- data sets of the solutions must be provided,
- video comment most welcome.
data set for download: https://autode.sk/2n8PsRc
Cris
https://simply.engineering
