- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
I am currently using Inventor and Vault Professional 2024 and I recently discovered the new finish feature.
Before we used to paint everything by using the appearance menu, but the finish feature is much better for us. The main issue that it solves for us is that we offer our clients the choice of paint. In the past, we tried to experiment representing this through the representations tab, but I hear that it was not a success (I was not actually here at the time and I have not confirmed for myself). With the new finish feature, we can easily have multiple paints for the same part/assembly and all we have to do is select the appropriate model state as necessary.
The issue I ran into is that when we release parts/assemblies (vault automatically creates PDFs and DXFs for us), the drawings do not include the finish that is linked to the primary state. Any views with that have the primary state have the default colour of the material of the part/assembly. Any views that refer to other model states work fine.
Was I wrong to link a finish to the primary state? When I first tested this, I created a manual PDF and it worked fine, but now the same PDF created through Vault shows the primary state without the finish, as if it's no there. What am I doing wrong?
Thank you all in advance!
NOTE: Attached PDFs have the view on the left as the primary state, and the right one as the other state I created, both have been created at roughly the same time
