Finding the 'Construction' button
Vagulus
Vagulus
I need construction lines in a sketch but my 'Construction' button has gone AWOL.
I can get it back in a 'User' tab but even then it doesn't activate.
How do I get it back (I seem to remember it was in the 'Format' tab)?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Frank-Oosterwaal
Is the whole format tab gone?
If so, RMB on the ribbon -> Show panels -> Select "Format"
If that's not the case try resetting the ribbon:
RMB on the ribbon -> ribbon appearance -> Reset ribbon
If nothing of the above works, what happens if you select the line in the sketch and RMB -> select "Construction"
Does that work?
Vagulus
Sorry about that.  Should have included this
I am working on a custom drawing template and am currently editing the border, so its not an ordinary sketch.  I don't know if that makes any difference.
Albert Einstein
-niels-
@Vagulus wrote:
...drawing template...  I don't know if that makes any difference.
Yes it does, no construction lines in the idw/dwg environment.
If you do not want your lines to show up when exiting the sketch mode you have to make them "sketch only" by using the button visible in your screenshot.
Other than that you can change the formatting of the line (linestyle, color, etc) using the options in the dropdown when clicking on "format".
Hope that helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Vagulus
Thanks for that
Albert Einstein
