Inventor template drawings for standard sizes
I am looking for standard out-of-the-box drawing templates (*.idw) for Inventor 2014. I got the template in C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Metric\ISO.idw , which is A3 size. Where can I find or get the out-of-the-box Inventor drawing templates (*.idw) for other standard sizes - A0, A1, A2, A4?
Regards
PV Subramanian
Mark.Lancaster
@Anonymous
In the Inventor browser window pane for your template or drawing.. If you right mouse click on Sheet 1 and select Edit Sheet..  You can then change the format sizes.  Meaning there's not individual templates for each size.
Mark Lancaster
Paul-Mason
You can get out of the box AO, A1, A2.  when in the drawing environment by one of two ways
By HIGLITING "SHEET 1" then RMB
and selecting EDIT SHEET then select size you want from the list as below.
OR
Create new templates for each size you want then save each as a NEW TEMPLATE or create one new template with ALL the size that you want then FILE, SAVE AS then select NEW TMPLATE , give it a name that you will remember, then change sheet size/layout as needed this way you can then have several different sheets size in one IDW file.
Once you have created your new template it should, if you saved it in the correct location, show in the list/windows of templates when you select/click on new IDW icon
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Memory 128 GB (128 GB usable)
Graphics Card NVIDIA Quadro P4000 (8 GB)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
