I've inherited a guitar contoured top which I am working on and edited to use as a template for my next custom CNC build. I'm happy with everything about it except that there are some cutout holes in the top which are in the wrong place. I need one erased and two moved up the body slightly. I will most probably need to erase them all and create new ones in a different location. However when removing the cutouts I can't get to a result which is consistent with the rest of the top.
Using Autocad I tried to fill these using the patch tool which just came out flat, or "saggy". I also tried filling with a separate object, which seems more reasonable as I could sand flush by hand once cut out, but would still prefer to get it right in CAD the first time.
I was previously using autocad until I discovered it is incapable of completing this task and was forwarded onto Inventor. Can someone help me with this one?
Attached are photos to show what's going on, and a DWG of the file.
Original Top
The Yellow circles are where they need to be moved to.
Filled with Patch Tool
Filled with Solid Object
