Filling in Holes on a Contoured/Curved Surface?
archienancarrow
archienancarrow
I've inherited a guitar contoured top which I am working on and edited to use as a template for my next custom CNC build. I'm happy with everything about it except that there are some cutout holes in the top which are in the wrong place. I need one erased and two moved up the body slightly. I will most probably need to erase them all and create new ones in a different location. However when removing the cutouts I can't get to a result which is consistent with the rest of the top.
Using Autocad I tried to fill these using the patch tool which just came out flat, or "saggy". I also tried filling with a separate object, which seems more reasonable as I could sand flush by hand once cut out, but would still prefer to get it right in CAD the first time.
I was previously using autocad until I discovered it is incapable of completing this task and was forwarded onto Inventor. Can someone help me with this one?
Attached are photos to show what's going on, and a DWG of the file.
Original Top
The Yellow circles are where they need to be moved to.
Filled with Patch Tool
Filled with Solid Object
Replies (10)
JDMather
What version of Inventor do you have?
JDMather
Are you intended unit inches or mm?  (The file that you attached is inch - and huge geometry???
JDMather
You can use Delete Face with the Heal option to remove these features.
johnsonshiue
Hi! Yes, JD is right. You can use Delete Face -> Heal to remove the holes. Before you do that, you may want to repair the body. The 3D body checks very poorly in quality. Right-click on the base feature in Inventor -> Repair Bodies -> Find Errors -> select the body. Then do Heal Error with 0.00001mm tolerance. You can double-click on each remaining failure to see some options. Make sure the geometry is as tight as possible (0.00001mm). I usually would use Unstitch and then Stitch them back at 0.00001mm.
Many thanks!
Software Test Engineer
archienancarrow
Hi, thank you for the replies, I have yet to go back and check my version, I will try this solution as soon as I am next able to get to my editing computer. My units are in mm on autocad and not inches, they seem to default to inches on saved files for whatever reason.
archienancarrow
That all worked out better than I hoped. The only other thing I need to do is put those cutaway dips back in but in the new allotted places cut out in the top. Is there an easy way to do this?
JDMather
Are you using Inventor?
Or are you using AutoCAD?
archienancarrow
I have a copy of both autocad and inventor on my computer. Currently I am working in inventor because it seems more suited to my needs. However I am much more used to autocad and it is more intuitive, so I tend to load back into that whenever joining and aligning models, or taking screen shots.
JDMather
When you Attach files here - they should be Inventor *.ipt files, not AutoCAD *.dwg files.
archienancarrow
Hang on got it saved here
