Filling a void
Filling a void
tmoxam
Filling a void
tmoxam
i have read several forum post on filling a void. Creating a derived component as the material in the void.
Im sorry but i dont follow the procedure.
What would be nice would be to pick the surfaces from the assembly as limits and then say 'go'.
That sort of seems to be what happens in derived components but, as soon as i select an item i get a cyclic dependency therefore my confusion.
Can someone please define the steps to creating a derived component to fill this void.VOID.JPG
JDMather
Can you Attach the assembly here (or at least a simplified mock-up)?
johnsonshiue
Hi! The process is not that difficult. However, it does depend on the existing geometry. The idea is pretty simply. Basically, you want to fill the hollow space, right? But, you don't want to fill the hollow within the tube, right?
For the area you don't want to fill, you need to make sure it is solid. Please share the files here if you cannot figure out.
Many thanks!
Software Test Engineer
IgorMir
Tim;
Since you have mentioned you are having a problem with the cyclic dependency - I am guessing - you derive the same assembly into a new part, which you want to representing a fill. Than you try to put that part into your assembly and getting a cyclic dependency error. If I am right - you need to create a new assembly (call it Master assembly, for example) and put all the parts you need for creating a void fill in there. Those parts being the same for your Main assembly. Once you create a void part - that part will go into the Main assembly without an error.
I will try to make you a sample in a moment.
Cheers,
Igor.
Web: www.meqc.com.au
IgorMir
Here it is, Tim.
The files are in IV2020 format. Technically - there is no need to create a Master assembly for this exercise. The Spiral and Heat Element could be derived into the Void.ipt as solid bodies. But I went that way just to show you the way to avoid cyclic dependency in assemblies.
Cheers,
Igor.
lena.talkhina
Hello @tmoxam  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
