I don't understand why this Fillet would fail when it was fine before I changed the length of the edge. See before and after shots attached..
The geometry/features that are used to create the fillet are exactly the same.
Is it possible to post the IPT with the failing Fillet feature here? If it's not possible/appropriate to post the model publicly, you can email it to myself (jake.fowler at autodesk.com) so that we can investigate what's going wrong here.
Many thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
