Is there a Option or Flag available in Inventor Application/Document Settings which restricts the user from loading the file having same name.
Scenario:
I have one file in a location D:\Autodesk\Location1\Part1.ipt and second file in D:\Autodesk\Location2\Part1.ipt. (The Geometry and properties might be same or might not be same).
I open the first file Part1 from D:\Autodesk\Location1\Part1.ipt. Now this first file is loaded in Inventor session.
Now if i try to open second file Part1 from D:\Autodesk\Location2\Part1.ipt inventor should not allow me to open. (By Default Inventor allows, as the Location is different)
This is the case i want Inventor to handle...
Is there any option which i can enable to acheive this.?
Hi Santosh,
no there are no option like that in the application option.
The only setting about unique file names that you can find is in the project setting:
From Inventor guide:
"Using Unique File Names: Specifies intent to create unique names for all files in the project (including the subfolder). Not applicable for library locations.
I hope that it can helps you Santosh.
Admaiora
