Files in Session
This widget could not be displayed.
Files in Session
Is there a Option or Flag available in Inventor Application/Document Settings which restricts the user from loading the file having same name.
Scenario:
I have one file in a location D:\Autodesk\Location1\Part1.ipt and second file in D:\Autodesk\Location2\Part1.ipt. (The Geometry and properties might be same or might not be same).
I open the first file Part1 from D:\Autodesk\Location1\Part1.ipt. Now this first file is loaded in Inventor session.
Now if i try to open second file Part1 from D:\Autodesk\Location2\Part1.ipt inventor should not allow me to open. (By Default Inventor allows, as the Location is different)
This is the case i want Inventor to handle...
Is there any option which i can enable to acheive this.?
Can anybody Help me out...?
admaiora
Hi Santosh,
no there are no option like that in the application option.
The only setting about unique file names that you can find is in the project setting:
From Inventor guide:
"Using Unique File Names: Specifies intent to create unique names for all files in the project (including the subfolder). Not applicable for library locations.
  • Select Yes to indicate that no duplicate file names are used in the project. If a file is moved into the project, Autodesk Inventor searches through all editable project locations to find the file name, even if it was last accessed from a different folder.
  • Select No to indicate that duplicate file names exist in the project. If No, and duplicate file names are found when resolving files, the Resolve Files dialog box opens so you can browse to the correct file to manually reestablish the link."
I hope that it can helps you Santosh.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Hi admaiora,
This can be used for creating a project and managing files within a project.
What if i try to open files with same from different location ?
I have explored everything in Inventor, I am convinced that there is no option in Inventor to handle this scenario.
Thank You for your reply.
