File Navigation bar 2021
I accidently switch my window layout while working on a project and now my file navigation at the bottom of the screen is gone. Its the tabs that quickly allow you to switch back and forth between files that you have open at the same time. 123.PNG
JDMather
I didn't find the option for just that issue, but you might try the Inventor Reset Utility.
johnsonshiue
Hi! Also make sure 2021.3 update is installed.
Many thanks!
Software Test Engineer
