File, file, where is the file?
不适用
320 次查看
3 条回复
1 条消息(共 4 条)
不适用
2016 professional, I Paste Special an Excel file into my .idw. I delete the original excel file, then double clip the embedded excel file to edit, it opens and all works very well, but where is this embedded file then stored?
J.
0 个赞
321 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
Mark.Lancaster
@Anonymous
Usually its located in your personal temp (%temp%) folder and its called some odd name..  极度高兴的表情
Mark Lancaster
3 条消息(共 4 条)
不适用
So, forever embedded into the idw file.
0 个赞
4 条消息(共 4 条)
mcgyvr
an embedded file is embedded in the file 眨眼表情
It can be removed/deleted from the file if you want..
0 个赞
