FEM-not enough memory to continue the process
christian.hoetzel
Message 1 of 22
christian.hoetzel
Community Visitor
Community Visitor
hi everybody,
not enough memory to continue the process- FEM. What should be adjusted here to finalize the analisys ? would be happy for support.
Replies (21)
Message 21 of 22
shaun_mabey
Capture.PNGI am having the same issue on 2022.  I have tried the steps in the other referenced thread "
Close Inventor
Start REGEDIT and go to the following registry key (create one if it does not exist).
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Simulation\RegistryFEACS]
Create a DWORD underneath.
Name it "EnsureContactDensityPasses" and set the value to 0.
Start Inventor and perform the mesh workflow"
but no luck, any other solutions?
Message 22 of 22
johnsonshiue
Hi! It could be that there is indeed not enough memory. If you try a smaller assembly or a part, does the same error persist?
Go to the modeling environment and press Ctrl+F7. Is there any bad body reported?
Many thanks!
Software Test Engineer
