Inventor Forum
Fehler beim Laden
14 REPLIES 14
Message 1 of 15
481 Views, 14 Replies
Fehler beim Laden
In my company sew users are always getting an error message.
English translation of this error message is "Error loading segment PDesignViewSegment in datatbase"
Can someone help me to rectify this problem?
Dinesh
Tags (1)
14 REPLIES 14
Message 2 of 15
Fouad-l
Hi @Anonymous and welcome to Inventor Forum.
Please tell us which version of inventor do you use, and if you have instaled the latest service pack.
I think this article will help you.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Opening-data-generates-Error-loading-segment-PmBrepSegment-in-datatbase.html
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Message 3 of 15
in reply to: Fouad-l
Hi @Fouad-l
I'm using Inventor 2017 and service pack is 4.
I dont have Inventor 2010 or 2011 to perform this test.
Is there any other possibilities?
Dinesh
Message 4 of 15
Mark.Lancaster
@Anonymous
It sounds like to me the file has some corruption in it.  Is it possible to share here to see if others have the same results.  You may want to look in the oldversion folder in the same location where your file is stored.   Maybe the existing save/backed up file is good.
Mark Lancaster
Message 5 of 15
Fouad-l
Was this part designed originaly in an older version of inventor?
Message 6 of 15
johnsonshiue
Hi! The error means Inventor has trouble loading certain segments of the part file. It is usually caused by corruption. Do you have prior versions of the ipt file?
Many thanks!
Software Test Engineer
Message 7 of 15
mdavis22569
in reply to: johnsonshiue
After this is solved:
There is now a German speaking forum
https://forums.autodesk.com/t5/deutsch/ct-p/59?nobounce
Mike Davis
Message 8 of 15
in reply to: Mark.Lancaster
@Mark.Lancaster
It often happens during measurement. Will it be a problem because of a corrupted file?
Message 9 of 15
johnsonshiue
Hi! It seems that you are running to a few corruption issues. I would like to double-check that you are trying to open files saved in 2017 or earlier releases on 2017, right? 2017 is capable of referencing 2018 ipt and iam files, which is called Future CAD workflow. But, you will need to install Update 4 to enable the ability.
Many thanks!
Message 10 of 15
Hi @johnsonshiue,
I have installed the latest version of Inventor 2017, i.e.2017.4.
But in Properties --> iProperites __> Details, it shows as 2017.3. But build number is 256, which is the latest from 2017.4.
Dinesh
Message 11 of 15
Hi @Fouad-l
This problem occurs normally in the assemblies.
It contains some parts (.ipt) which were created before 15 years.
Dinesh
Message 12 of 15
Fouad-l
Hi @Anonymous
Can you please try if this workaround solves the problem?
1) Open the component in Inventor. --> move up "End of Part" on top of browser --> save and close.
2) Open it  again -->move down "End Of Part" at the end of browser --> save.
Message 13 of 15
Hi @Fouad-l
Thank you. Sure. I will try these steps.
This problem doesn't occur everytime. It occurs in different assemblies at different time.
Assume that, I am trying to open an assembly 1 and I got this error. So I will close the inventor and open it again. It works.
Like this, it happens for too many users.
I will try your solution andif it works, I will "accept as solution".
Tags (1)
Message 14 of 15
matthias_schindler
Hi all,
This forum topic are become now with the Autodesk-Support, because this is an very particular topic.
If we have the case finish, I get post here the solution, if we can this post here public.
Matthias Schindler
Technical Support Specialist for Inventor
Message 15 of 15
We found the solution for this issue.
This problem is due to UTF-8 tool.
I would like to thank @johnsonshiue @Mark.Lancaster @Fouad-l for your interest to solve this issue.
