FEA report missing images
hvandeweerd
Message 1 of 26
hvandeweerd
FEA .html report looks for .BMP images. But while creating the report .PNG images are saved on disk. So the report is missing some images (not all images are missing)
(I'm using IV 2021.1 build 245 with Windows-10-64, build 120.2212.31.0)
Replies (25)
Message 2 of 26
johnsonshiue
Hi! This page may provide some hints.
https://www.cadlinecommunity.co.uk/hc/en-us/articles/115003399249-Inventor-Missing-Images-on-Stress-...
Many thanks!
Software Test Engineer
Message 3 of 26
hvandeweerd
The report looks for .PNG images, but .BMP images are created.  It appears to be a security issue within windows.
Message 4 of 26
JelteDeJong
I have the same issue. Do you know a solution? Or can u point me in the direction of this "security issue within windows"
Jelte de Jong
Blog: hjalte.nl - github.com
Message 5 of 26
hvandeweerd
Helaas kom ik niet verder met dit probleem. Ik weet geen oplssing.
Message 6 of 26
hvandeweerd
Maybe this is a solution: see thread https://forums.autodesk.com/t5/inventor-forum/can-t-export-results-from-design-accelerator/m-p/92454...
I have copied the design data content from the standard install-location to the custom location where my templates are.
Message 7 of 26
JelteDeJong
The solution was not clear to me and I had to search for the correct files to copy.  I copied the following directory:
C:\Users\Public\Documents\Autodesk\Inventor 2021\Design Data\Simulation\Report\
to
<My custom Design data folder>\Simulation\Report\
I updated from Inventor 2018 to 2021. The only file that changed is:
C:\Users\Public\Documents\Autodesk\Inventor 2021\Design Data\Simulation\Report\Configuration.htm
For me that is the only file that I needed to copy.
Jelte de Jong
Message 8 of 26
chris.harbour
I am getting this too regardless of the format i save the report in. The first 2 or three images are there but the rest are missing.
(IV 2022.1.1)
Message 9 of 26
JDMather
@chris.harbour
Can you Attach your file here?
Message 10 of 26
chris.harbour
Here is a pdf example.
Message 11 of 26
hvandeweerd
Here is also an example. Missing pictures are: Von Misses stress, 1st and 3rd Principal stress, displacement and safetey factor. I have adde these files manually to the pdf.  So, the files exist but are not added to the .HTML file.
Message 12 of 26
chris.harbour
Why add them manually, they should be in the report.
Message 13 of 26
hvandeweerd
That's exact the problem, they are not in the (HTML) report.
Message 14 of 26
chris.harbour
And not in the PDF or any of the other file formats.
Message 15 of 26
hvandeweerd
The HTML contains links to .BMP pictures. But the the last five links looks for .PNG files.  The pictures are all created as .BMP files. Maybe it's a problem in Windows with the file-extensions.
Message 16 of 26
chris.harbour
So basically you are saying that the FEA reporting is broken.
Message 17 of 26
JDMather
@chris.harbour
Why would I want a pdf file.
How would I use that file to diagnose the issue?
Message 18 of 26
chris.harbour
Because that's where the issue is. There should be images in the PDF there are not. That is the issue.
Message 19 of 26
hvandeweerd
I just created a sample file. I also created 3 types of report. .HTML, .MHTML and .RTF. All are wrong.
Message 20 of 26
infoKU5RT
Any solutions concerning this issue? I'm running into the same problem.
