Im trying to Cut with an extrusion but it wont let me and the choice to cut whe your trying to extrude is gray and wont let me choose it and its only like that for one peice on my autodesk inventor. How do i fix it? is their something i turned off on accident, how do i turn it back on its irritating me?
You couldn't Extrude cut, because your Delete Face operations turned your solid into a surface. After removing them, Extrude Cut can be done. (see attachment)
I think, there are still errors in your model. But I don't know, for what it's good all about.
Walter
Walter Holzwarth
@af8777
Welcome to the forum. Can you explain in a little more detail what you are struggling with? Maybe share your file here so our experts can take a look at it?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
As @CGBenner has requested, can you elaborate a bit more?
Based on just the screen cap you posted, looks like there isn't any geometry to use for the extrusion.
Again, we'll need more information.
Jim O'Flaherty
Hi! This particular error is associated with an iMate. This means the Extrusion is removing the geometry defining the iMate. Either delete/suppress the iMate or change the profile so that it does not remove the iMate.
Many thanks!
