extrude text in block sketch
I have a logo containing free shapes and text. I want to extrude these to create a cut out in a sheet metal part. Works perfectly fine!
However I want to place the logo in a sketch block. This way the free form and text stay in the right position relative to each other while I move the logo over my sheet metal part to position it. Now the extrude does not seem to work anymore! The free form shape does extrude but the text does not.
Any ideas on how to fix this?
Rob67ert
Can you post you part here?
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Curtis_W
Hi reneetoussaint,
Unfortunately that's just the way it works Smiley Frustrated (I'm not sure why?)
What you can do, is place the block as needed, then right-click on it and choose Explode.
I hope this helps.
Curtis
mcgyvr
I would make the logo a sheet metal punch..
Then a single sketch point can be used to place it where you want easily..
And if done properly (custom parameters that show up in the size tab of the punch tool dialog box on placement) you can size it as needed too..
hi @Anonymous
I have attached a small video, please check if this works for you
Thanks & Regards,
Tushar
If it is not possible this certainly is a nice alternative. I am going to give it a try 🙂
MatsNorway1
The year is 2024, and text in blocks can still not be ekstruded. And exloding blocks is often denied.
‌:nauseated_face: ‌:face_with_medical_mask: Fusion 360
