Inventor Forum
Extrude a bitmap?
3 REPLIES 3
1005 Views, 3 Replies
Extrude a bitmap?
I have a logo / silhouette that needs cut into a sheetmetal part. Can I
import this into a sketch and extrude it, or do I have to sketch around it?
I would like to know if it worked like type does, that works nice.
Also, can you create type on an arc?
Jerry
Extrude a bitmap?
Jerry
3 REPLIES 3
If not too complex you can bring your logo bmp in as a decal and trace
around it with a sketch, Otherwise do a google search for "raster to vector"
there a quite a few various pieces of software that will convert bmp to dxf,
the file will prob need a lot of clean up.
For the arced text check out the 3D text tool from www.cbliss.com
"Jerry Chasek" wrote in message
news:FF1FCF3EE30E50EB04AE3CD5A0EBB93B@in.WebX.maYIadrTaRb...
it?
> Jerry
it?
> Jerry
To use the decal tool I believe you have to have a solid to start with. You could make a
very thin extrusion the size of the logo, and then add the bmp
Also there is some raster to vector programs like wintopo http://www.wintopo.com/ that
output a DXF file. Someone posted that they liked some other brand better, but I don't
remember what it was. If you do a search of the groups for Wintopo you will probably find
the thread.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> Jerry
the thread.
Kent
Assistant Moderator
> Jerry
I'll download the 3d text tool and I already have the wintopo, haven't had
much luck with that. too much cleanup work, just as well start from scratch.
Jerry Chasek
"Kent Keller" wrote in message
news:E80E184F855CC957950E79A6216FBC1E@in.WebX.maYIadrTaRb...
You could make a
better, but I don't
will probably find
> the thread.
> Kent
> Assistant Moderator
it?
> > Jerry
Jerry Chasek
You could make a
better, but I don't
will probably find
> the thread.
> Kent
> Assistant Moderator
it?
> > Jerry
