Inventor Forum
Dimensioning to theoritical sharps
5 REPLIES 5
183 Views, 5 Replies
How do you create dimensions in an idw to theoritical sharps? I need to
give dimensions of tapered geometry at a common plane.
Bob L.
Bob L.
5 REPLIES 5
I'm not sure if I get exactly what you're asking for but it sounds like you
could dimension to the apparent intersection of the tapered edges. Start a
dimension, select one edge, RMB and select intersection, select the other
edge. After that select the plane to dimension to and you should get it.
Pat
"Bob L." wrote in message
news:9CED7C5DBDA44438EB6DBA0269B05ADD@in.WebX.maYIadrTaRb...
> Bob L.
Pat
> Bob L.
Use the dimension tool and pick on the first edge of your part then right
click and pick intersection then pick the second edge. It will take a little
getting the hang of it but it works great.
> Bob L.
> Bob L.
Hey we both gave the same answer so it must be the correct way to do it
"Albert Allen" wrote in message
news:900D14B0045F7284E6968BC4A1D9BE22@in.WebX.maYIadrTaRb...
little
> > Bob L.
little
> > Bob L.
Yeah, the only other option I could think of would be to sketch in the
extension lines and then dimension at the intersection, but why?
Pat
news:75F3A7401FB05E172F68519F1C78FEDE@in.WebX.maYIadrTaRb...
Pat
Thanks everybody! It is slick. I just have to be patient and not rmb to
quickly.
Bob L.
"Patrick Berry" wrote in message
news:C3027976B4B9C48F2B3C0BB05810F9ED@in.WebX.maYIadrTaRb...
> Pat
quickly.
Bob L.
> Pat
