Inventor Forum
Extract value from leader text
5 REPLIES 5
286 Views, 5 Replies
If I have a 2D drawing with an assembly and have 5 leaders (Leader Text). Would it be possible to extract that value from Leaders to an excel og xml file?
5 REPLIES 5
Mark.Lancaster
@Anonymous
Via some coding I would assume so but nothing out of the box is going to do this for you..
Mark Lancaster
Sergio.D.Suárez
Hi, Try this ilogic rule on the drawing sheet, take all the data from the leadernotes and place them on an excel sheet.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim OFullName As String = oDoc.FullFileName
'Remove file extension
Dim oExcelName As String = Left(OFullName, (InStrRev(OFullName, ".", - 1, vbTextCompare) - 1)) & ".xlsx"
Dim row As Integer = 2  ''' Indicate from which row the read of excel values will begin
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Add
xlWorksheet = xlWorkbook.Worksheets.Item(1)
For Each oLeaderNote As LeaderNote In oDoc.ActiveSheet.DrawingNotes.LeaderNotes
	oValue = oLeaderNote.Text
	xlWorksheet.Range("A" & row).Value = oValue
	row = row + 1
Next
'set all of the columns to autofit
xlWorksheet.Columns.AutoFit
'save the file
xlWorkbook.SaveAs(oExcelName)
'xlWorkbook.Close
'xlApp.Quit
'xlApp = Nothing
 I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
in reply to: Sergio.D.Suárez
That's really great!! Thank you!
Here comes next (tricky) part...
Now that I have my extracted value in column A, I would like to enter a Value in column B, that will replace the value in column A, once I import the values from my excel spreadsheet back into my drawing ...if it's possible to import that value back into the drawing?
Maybe the workflow could be that I
1. Insert leaders
2. Run the extract rule
3. Add values in column B, that will replace the values in column A
4. Save and close the spreadsheet
5. Run an import rule, that does the replacement of values in my leader texts
We would use it for TAG numbering on a layout, where we usually reserve the leader text with an $ and replace that text once we the TAG numbers from out PLC department
Sergio.D.Suárez
I do not fully understand the reason for using the excel table.
Could you try this simple code?
	newValue = InputBox("Replace value: " & oValue, "Replace LeaderNote", oValue)
	If newValue <> oValue Then 	oLeaderNote.FormattedText = newValue
Next
 This code changes each text of each leadernote. I think it would be more convenient than what you are looking for, in addition to not generating a new excel file. Excuse me if I do not understand the behavior of what you need, regards
Mechanical Designer
I've made the interface (see attached), maybe that gives and idea of what I'm making
What I want to do, is to run a sort of a batch job where the value in A2 gets replaced by the new value from B2
