If I have a 2D drawing with an assembly and have 5 leaders (Leader Text). Would it be possible to extract that value from Leaders to an excel og xml file?
@Anonymous
Via some coding I would assume so but nothing out of the box is going to do this for you..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi, Try this ilogic rule on the drawing sheet, take all the data from the leadernotes and place them on an excel sheet.
Dim oDoc As DrawingDocument = ThisDoc.Document Dim OFullName As String = oDoc.FullFileName 'Remove file extension Dim oExcelName As String = Left(OFullName, (InStrRev(OFullName, ".", - 1, vbTextCompare) - 1)) & ".xlsx" Dim row As Integer = 2 ''' Indicate from which row the read of excel values will begin xlApp = CreateObject("Excel.Application") xlApp.Visible = True xlWorkbook = xlApp.Workbooks.Add xlWorksheet = xlWorkbook.Worksheets.Item(1) For Each oLeaderNote As LeaderNote In oDoc.ActiveSheet.DrawingNotes.LeaderNotes oValue = oLeaderNote.Text xlWorksheet.Range("A" & row).Value = oValue row = row + 1 Next 'set all of the columns to autofit xlWorksheet.Columns.AutoFit 'save the file xlWorkbook.SaveAs(oExcelName) 'xlWorkbook.Close 'xlApp.Quit 'xlApp = Nothing
I hope this helps. regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
That's really great!! Thank you!
Here comes next (tricky) part...
Now that I have my extracted value in column A, I would like to enter a Value in column B, that will replace the value in column A, once I import the values from my excel spreadsheet back into my drawing ...if it's possible to import that value back into the drawing?
Maybe the workflow could be that I
1. Insert leaders
2. Run the extract rule
3. Add values in column B, that will replace the values in column A
4. Save and close the spreadsheet
5. Run an import rule, that does the replacement of values in my leader texts
We would use it for TAG numbering on a layout, where we usually reserve the leader text with an $ and replace that text once we the TAG numbers from out PLC department
I do not fully understand the reason for using the excel table.
Could you try this simple code?
Dim oDoc As DrawingDocument = ThisDoc.Document For Each oLeaderNote As LeaderNote In oDoc.ActiveSheet.DrawingNotes.LeaderNotes oValue = oLeaderNote.Text newValue = InputBox("Replace value: " & oValue, "Replace LeaderNote", oValue) If newValue <> oValue Then oLeaderNote.FormattedText = newValue Next
This code changes each text of each leadernote. I think it would be more convenient than what you are looking for, in addition to not generating a new excel file. Excuse me if I do not understand the behavior of what you need, regards
Mechanical Designer
I've made the interface (see attached), maybe that gives and idea of what I'm making
What I want to do, is to run a sort of a batch job where the value in A2 gets replaced by the new value from B2
