Extents and thickness in BOM
Hi Mates,
I've been digging forums for a long time to find answer, still no luck. Most of the answers shows only how to export extents to the parts list on a drawing.
I need them in BOM. So, if I insert that part into an assemby, I'd like a column in Runtime Column Customization that shows my custom parameter.
I attached a part named 37163565.ipt that calculates the two dimensions ("teritek_A" and "teritek_B") of flat pattern based on an iRule. Another attachment, Assembly1.iam, where I'd like to see my custom parameters in BOM. Is it possible?
Thanks in advance,
m.reyes74B3T
Could you calculate the thickness or input it manually as a custom iProperty? Then you could follow this to have it in your BOM.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Once it's an iProperty you can select the "Add Custom iProperty Columns" button in the BOM manager and add it as required.
bradeneuropeArthur
try this:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
These are custom iProperties, too, I guess. Even so, the "Add a custom iProperty column" is grayed out. I've tried with "extent_A" parameter by THIS method.
Great, thanks! Now I have to figure out, why "teritek_B" doesn't show up... and do this with Thickness, too.
edit: nevermind, I can type in.
bradeneuropeArthur
Maybe an empty "space" in the property definition!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
For the record
Using this iLogic form makes it simplier:
iProperties.Value("Custom", "extent_dim_A") = Round(SheetMetal.FlatExtentsLength, 2)
iProperties.Value("Custom", "extent_dim_B") = Round(SheetMetal.FlatExtentsWidth, 2)
iLogicVb.UpdateWhenDone = True
