Exporting Large Assembly into a step file
ATaha9THAF
ATaha9THAF
We are exporting a large assembly into a step file is approximately 373Mb and its currently been more than an hour since we started exporting. We already used simplify to reduce the file size and complexity as much as possible.
So my question is how long does it take to export something of that size? Is there anyway to definitively see that Inventor is frozen/working?
Additional Info:
Export Settings used:
- Application Protocol - 242 Managed Model Based 3D Engineering
-Spline Fit accuracy - 0.010mm
Frederick_Law
Hard to tell.
Let it run overnight.
I had STEP files I import overnight.  Start it at the end of the day.
Mark the time you start and check file modified time after.
ATaha9THAF
Can you expand on this
Nevermind just realized what you meant.
ATaha9THAF
At this point its been about 3 hours trying to export the file to me this seems like its frozen. But I would like confirmation before I end the task
Frederick_Law
Open Windows Task Manager.
See if IV cpu and memory use changes, also drive usage.
See if STEP file got created yet and if size is increasing.
It could be in some Temp folder.
ATaha9THAF
Good News everyone the step file was created 😄
The file is about 5 GB it took 3 and half hours but it we did it
great job team!
johnsonshiue
Hi! If you want to cut down the STEP file size, you could try loosening up the export tolerance. On exporting to STEP, click on Options button in the dialog -> change Spline Fit Accuracy to 0.01mm. The STEP file should be smaller.
Many thanks!
Software Test Engineer
